Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 3.0 |
| Print at Sep 19, 2026, 7:02:43 PM |
| Posted by sgabu77 at Dec 1, 2010, 4:41:42 PM |
Re: Sweet Home 3D 3.0 no, the floor is selected. here's another example |
| Posted by sgabu77 at Dec 1, 2010, 4:44:00 PM |
Re: Sweet Home 3D 3.0 correction of the post before. the ceiling is selected.sorry |
| Posted by sgabu77 at Dec 1, 2010, 6:19:59 PM |
Re: Sweet Home 3D 3.0 Good evening guys. I did several tests with my textures, and I noticed that the problem occurs at random with different textures and different files. I think, but I do not know if it is possible that the advanced rendering 1.6.1 is not fully integrated with the new version. Greetings to all. :) |
| Posted by hansmex at Dec 1, 2010, 6:29:57 PM |
Re: Sweet Home 3D 3.0 Sgabu, Can you share your file, so I/we can have a look at it? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by sgabu77 at Dec 1, 2010, 6:42:38 PM |
Re: Sweet Home 3D 3.0 ok. thank you. in the rar file there are the project and the old render version 2.6. see you tomorrow. LINK |
| Posted by Puybaret at Dec 1, 2010, 7:18:12 PM |
Re: Sweet Home 3D 3.0 The parameters set in the Advanced rendering plug-in won't be copied back to Sweet Home 3D v3. Set North direction to 90°, date to 1st september, hour to 13:00, remove ceiling lights, and you will have the same results as the image you joined in your linked file. Hope this was what you were looking for. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by PtiNounours at Dec 1, 2010, 8:42:32 PM |
Re: Sweet Home 3D 3.0Hey, SweetHome3D is released in Final version 3. Congratulations Mr Puybaret for this excellent version. I see in this version, it is possible to copy the walls in another instance of SH3D! Would this approach for the management of floor? For a moment, I took a dream to group all of my building and implementing an elevation , but the walls remain attached to the ground.question separately. you're reaching you of can't select the furniture? some are inaccessible, and I can not change them items or delete. PtiNounours |
| Posted by PtiNounours at Dec 1, 2010, 8:50:47 PM |
Re: Sweet Home 3D 3.0 my bug is not a bug. I remember that in this version the furniture can be locked. sorry |
| Posted by Puybaret at Dec 1, 2010, 9:14:08 PM |
Re: Sweet Home 3D 3.0 Thank you for your feedback. I see in this version, it is possible to copy the walls in another instance of SH3D! You could already in previous versions. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sgabu77 at Dec 2, 2010, 9:56:50 AM |
Re: Sweet Home 3D 3.0 The parameters set in the Advanced rendering plug-in won't be copied back to Sweet Home 3D v3. Set North direction to 90°, date to 1st september, hour to 13:00, remove ceiling lights, and you will have the same results as the image you joined in your linked file. Hope this was what you were looking for. Good morning I tried to set adv render as you told me and this is what I see. I'm afraid of not having done everything correctly. |
Current timezone is GMT Sep 19, 2026, 7:02:43 PM |
