Re: 2040 : Mars Two
All the crew on Mars wish you a HappyNewYear (to) Earth !
1920 x 1080 in Q4
In the sky, you can see the fireworks and ISV Hermes passes over the base camp...
[Edit 1 times,
last edit by bdfd at Dec 31, 2016, 6:04:48 PM]
Re: 2040 : Mars Two
Happy New Year to you, bdfd, your crew and all Sweet Home 3D users! Thanks for accepting to answer to our questions
Re: 2040 : Mars Two
Thank you Emmanuel. Long life and prosper !
01/01/2041 : The new year begins well (D 295), the inflatable cupola is OK.
1920 x 1080 in Q4
The crew will be able to live in while creating it. Finish the 'little' accomodation module.
The dome is made up of 2 inflatable envelopes: The first outer side (10 mm) is filled with ozone to filter the UV rays, The second inner side (20 mm) is filled with water to protect from other radiations.
Mars will be able to host the next missions.
Re: 2040 : Mars Two
Inside the airlock module, the crew sees the twice parts : front airlock and the main console of the engines.
Main console
Front airlock
1024 x 768 in Q4
After the silence of space, 'vrrrmmmmmmmmmmmmmm' the noise of the engines...
[Edit 1 times,
last edit by bdfd at Jan 3, 2017, 6:16:55 AM]
