White spots
This topic has been viewed 7455 times and has 4 replies
Thread status: Active
Post Reply New Topic
User avatar
fhoofman
White spots
Post by fhoofman »
i've tried using db4tech's floor on my project, and the white spots always appear
I'm using silk render and silk floors
can someone help me? or is there any update that I should know?
User avatar
Country: Netherlands
Re: White spots
Post by hansmex »
Yudi,
Can you share the original file with us?
hans
User avatar
fhoofman
Re: White spots
Post by fhoofman »
User avatar
Re: White spots
Post by hansmex »
Yudi,
1 - If you provide a file so others can investigate what's going on, it would be nice if your file is in the exact state in which you made your problematic render. Don't make people spend a lot of time to try and find out how you made your picture....
2 - You have a strange way of building models. Your floors are made of boxes that are 10 cm high, but furniture is invisible because it doesn't have a 10 cm elevation, there's no ceiling, walls are transparent, etc.
3 - There have been many posts in the forum dealing with light, sky and rendering. If I apply a texture to the sky (any texture!) the problem is solved.
db4tech
Country: UK
Re: White spots
Post by db4tech »
Hi fhoofman,
I also had a look at your file, sorry it's taken me a few days, not been well.
Hans,
The 10cm think floor is partly my fault, it was originally designed as a test for a first floor gallery model I was building at the time while doing the Uber and Phong shader tests. I later used the settings learned from the tests, to make a new first floor model of around 40cm. [:)]
Here is an updated image for comparison.
Are you building the model to help you learn, or is it for commercial reasons?
I ask because I didn't know if you wanted me to upload the version used for this render, or if you would prefer a step by step guide of changes made. [:)]
db4tech
