Previous Thread This topic has been viewed 196 times and has 9 replies
AvinashC
India
Plugin development issue
Hi all, I am new here and I am looking for a little support on how I can use an existing plugin and make changes to it. I have downloaded the source code of the sweethome3d and i am running the code in eclipse.
I have followed the steps given in the developers guide.
I have the jar file of the plugin code and i added it to the directory however on running the code there is no tools menu or the given name to the feature.
I am currently using MacOs 14.4.1
Am i missing something in the steps please let me know
[May 3, 2024, 5:09:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Plugin development issue
If the plug-in is stored in the right folder and classpath is correct, you must have something in the console which will give you some hints.
[May 3, 2024, 5:58:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AvinashC
India
The plugin was in a jar file and it got saved automatically in a destination in com.eteks.test and it has the ApplicationPlugin.properties file as well.
Is there any step i am missing here.
[May 3, 2024, 6:58:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hum… and what about the content of the console?
[May 3, 2024, 8:04:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AvinashC
India
WARNING: References to Carbon menus are disallowed with AppKit menu system on macOS 14 and newer. Use instances of NSMenu and NSMenuItem directly instead. See https://developer.apple.com/documentation/mac...-notes-for-macos-14#Menus
Apart from this warning there is nothing else on the console.
[May 3, 2024, 8:33:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Therefore it means that you didn’t place the plug-in in the right folder. Where did you store it?
[May 3, 2024, 9:21:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AvinashC
India
its stored in the SweetHome 3d > ReferencedLibraries > TotalSurface.Jar > com.eteks.tes > TotalSurface.class
and the ApplicationPlugin is stored in TotalSurface.jar > META-INF folder
[May 3, 2024, 10:09:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AvinashC
India
Not able move them either
[May 3, 2024, 10:10:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It may be not the good folder. See the section Creating the plug-in JAR in Plug-in developer’s guide.
[May 3, 2024, 10:31:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
By the way, Referenced libraries section in Eclipse just lists the libraries that you use in your project, not the real folder where is stored a file!
[May 3, 2024, 10:35:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
