Total posts in this thread: 4
Previous Thread This topic has been viewed 4388 times and has 3 replies Next Thread
seballa
Recover corupt file
Hi
I toyed around with SH3D today. When I finished my room, I saved it and tried to unzip the file succefully. After that I reopened the file did some changes and saved again. Unfortunatly something got wrong and I cannot open the file anymore now. I tried to zip the files again and rename the file but sweethome3d can't open them.
How do I repack an unziped sh3d file? Just ZIP and rename doesnt work
[Jan 8, 2010, 5:49:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Recover corupt file
It's not because a SH3D file is some kind of ZIP file that you should play with it in a zip program! sad
The only tip I can give you is that Home entry must be the first entry in a SH3D file, if you want Sweet Home 3D be able to read it. Don't ask more if it still doesn't work after that...
[Jan 8, 2010, 8:32:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
seballa
Thanks a lot Puybaret! It actually did work.
It was pure luck i played around with the file and unzipped it, because I did destroyed my file later.
This is what I did to repack the unzipped files:
I created a new ZIP only of the HOME file with winrar and used the compression setting: "save"
I then drag and droped all other files into this archive one by one in numeric order, after that I did the same with the folder.
I renamed the file from home.zip to myrecoveredfile.sh3d
AND IT WORKED.
THANKS
Seballa
[Jan 9, 2010, 12:49:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'm glad you succeeded! smile
The next time you want to compress your SH3D file, use File > Save and compress menu item. It's much easier! wink
[Jan 9, 2010, 1:01:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
