Re: Can we use api on our own website
What API do you mean? The Java API of the Online version or the JavaScript API of the 3D viewer which doesn’t allow to edit plans until now? If you plan to reuse the Online version on your web site, I would recommend to find another solution because it’s a dying solution, since it can work only in Internet Explorer with the latest version of the browsers. All the other ones gave up the support of plugins, including the Java plugin which is required to run the Online version.
