Problem with "Hole" Visibility while Import
Hello Dear Forum, im stil using sh3d for a while. Now i have a problem with the "hole"-visibility from objects. Using sh3d 5.7, today update to 6.0 - same problem.
1) 1st Hole - with Rounded Door from BuildIn Library 2) 2nd Hole - with WallOpeningInvisible 3) Red Arc - Rounded Door from Build-in-lib export to *.obj then reimport with door/window
At that moment the object is included in the wall, the hole is going lost? Same when i include it in the "Invisible Wall". This is happening with every Objects i import.
See the screenshot here:
I spent a couple of hours to find a solution, but i didn't find helpful informations.
Any ideas what i'm doing wrong, or what's wrong? Thank you for help. Peter
[Edit 1 times,
last edit by Puybaret at Oct 30, 2018, 1:53:38 PM]
Re: Problem with "Hole" Visibility while Import
Why exporting / reimporting models found in the default catalog? You'll lose their cutout. You should just use the models in the furniture catalog.
Romania
For a few versions ago is more simple. e.g. The straight way
Romania
Update
@dorin - WTF! How did you create this SVG-path? I always spend hours for creating a simple cutout for my boats and it would take my hole life to create a cutout like this one in your picture!
Pascal
Romania
Well, when You have a hammer over head You make a hole instantly. Now the steeps: 1. Peeve Your wife. 2. Export the mannequin as object; import as door 3. Insert it in a straight single (not splinted) wall. Will make the cut over contour. 4. Modify furniture -> Modify texture -> select all -> Invisible ->OK NOTE: It don't work on angled or curved walls even for simple forms.
hmm... I haven't thought it's as simple as this. It seems I'm often thinking to far... But I'm not sure if I can adapt this solution to my problem...
Pascal
