Italy
Re: Showcase your glassblocks
Thank you for the link.
And here is mine, a bathroom. Let me know what you think about it; I will be happy if you can give me some suggestions to resize the glass blocks in such a way to obtain a good result in rendering it because I do not like it very much. I tried many times but without success.
Italy
Hi rontant,
I think that the problem was that I rescaled the glassblocks without the "keep proportions" option selected while modifying them. I was able to create this living room:
Later I will repost the bathroom with the right proportions of the glassblocks.
Thank you for this post, I like creating rooms with this kind of glassblock.
Italy
Hi rontant,
I adjusted the glassblock of the bathroom, here it is:
Regarding your question about the painting, I was inspired by this living room found on the web, so if they have succeeded, it means that it could be done :).
In real life I would do it, for example, leaving the wall behind the painting so that it could be placed, and therefore not using the glass blocks on that point. I think that it should not be evident that they are not present because of the presence of the painting. In the project that I have posted, I have not used this technique because it is quite complex to do it with Sweethome3D.
In case of the picture of the living room I found in the web, I think that they used some kind of scotch tape to do that :).
