Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 3 4 5 6 7 8 9 10 11 12 | Next Page ]
Previous Thread This topic has been viewed 1151100 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
My only little problem now, is that my list of imported test textures has become ridiculous. Among a few good ones, there are many hundred totally useless, experimental images. smile It would be great if the texture import wizard had a check- box NOT saving an imported texture (other than in the .sh3d file) - like furniture.
..proposed an angle for the sky texture offset, but using a percentage seems more versatile in other cases...
Interesting interface issue considering some recent threads, e.g. Cec' brilliant guide in thread 8832, the Azure home, thread 8828 - and whether to use the compass to 'simulate'. People use different references for orientation and how they see the world. Whether to keep a map North up, or turn the map to align with terrain. Cec' template measures degrees from the point of view of the virtual visitor, whereas I need the compass orientation to read the 3D view.
Even if I in theory would prefer a degree angle sky texture, in practice conversion is easy and it makes no difference. And since percentage is more consistent with other textures and probably easier and more intuitive to use in normal cases, percentage is probably a better interface choice. (But if possible, I agree with ndorigatti that a hint could be a good idea.) And never mind the measure, the important thing is the function that works very well. Thanks again.
<texture attribute='skyTexture' xOffset='0.20833' .../>
<compass northDirection='1.3089969' .../>
<observerCamera yaw='1.3089969' pitch='-0.16801324' .../>
<camera yaw='4.456615' pitch='0.0' .../>
<pieceOfFurniture angle='1.3089969'...'/>
[Sep 11, 2018, 10:11:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great things are happening here! smile
I have finally been able to test this, and I can't wait to get my hands on the final version (or a non-web-start beta version).
It won't display any of my projects, but I managed to play a bit and create a small object or whatchamacallit – to utilize the sky offset spinner:
With sky offset, this joint will no longer be something I have to use time on :
My first project with v6 Beta8: Horizontal_Scale.sh3d It's not perfect, but it works.
... and the new colour palette is perfect smile
Question:
I use curved walls a lot when creating models, and I make custom textures for them. Of course I can open my calculator and calculate the length, which is what I do, but caould the math be included in the modify walls window?
(And it would be great if we could curve a wall 360° )
Great work!
Cecilia
[Sep 11, 2018, 8:51:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Very good, great features.
But I have a problem with Add point to room. It just sort of stops at the context menu item, and no point is created when context menu closes. Context menu still has highlight on Add point to room when context menu is opened again.
Could someone check whether it is just me?
[Sep 12, 2018, 11:39:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Same for me. And "Delete point from room" has also no effect...
[Sep 12, 2018, 2:17:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback and reporting the issue in the Plan contextual menu. It's fixed in the Beta 9 which brings also the following two new features :
- It's now possible to view the background image set at ground level in the 3D view too, by selecting the new check box Background image visible in 3D view in the 3D view modification dialog box.
- Each polyline may also be viewed in the 3D view with a new check box in its modification dialog. When the polyline uses a dash style, you can set an offset too, to shift the starting of the dash pattern.
These features are probably the last ones with user interface items that will appear in the coming version 6.0, so I can start to ask our great contributors to translate the new texts before considering a final release.
[Sep 15, 2018, 12:08:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
confused Re: Sweet Home 3D 6.0
Everybody Didn't see that the used compass was 'wrong' since few weeks ! biggrin
A personal compass taken in my hands tell us that (like e.g. below) :
North = 0°,
East = 90°,
South = 180° and
West = 270°.
What is the Reason ? confused
Regards,
bdfd.
[Sep 15, 2018, 6:38:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bdfd, the compass shown in Sweet Home 3D plan doesn’t show any angle.
And the X offset field of the sky texture lets the user shift that texture on the basis that the left border of the texture image will appear at the East for an offset and a compass angle both equal to 0. It could have been a better idea to consider that the left border of the sky texture is at North when its offset is equal to 0, but that would break the compatibility of previous SH3D files. I’ll see if I can add a N to indicate the North on the texture image preview to help users understand this.
[Sep 15, 2018, 9:11:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Update !
Wrong, remember this with the option 'update compass' :
I repeat for newbies : It's good with sh3d.
wink
[Sep 15, 2018, 9:25:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
applause Re: Sweet Home 3D 6.0
Beta 9
Very useful!!!
I think
1.we should add dimensions annotations to functions that can be displayed in the 3D view.
2.Polyline can be displayed 'vertical' in 3D view like 'text'
[Sep 15, 2018, 11:28:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bdfd, I think I understand what you mean now: Cecilia's Horizontal_Scale.sh3d test and other sky textures showing angles that she designed show a zero angle at South rather at North.
Cecilia, even if it's not so important, is there any reason for that?
By the way, to answer to your proposals, I shall add the middle length of a curved wall somewhere, but I don't think I will allow to curve a wall at 360°, because such a wall would have to start and end at the same point making its handling hardly usable in some cases.
But note that from version 6.0, you can spread a 360° texture along two walls attached to each other with an arc extent of 180°, by setting an X offset of 50% on the texture of one of the two walls (see example attached to this post).
During this test, I noticed that the texture coordinates along curved walls are not exact, because they don't take into account the thickness of the wall, meaning that the width of the texture applied on a curved wall is correct only for walls with a thickness equal to 0 (something that can't happen). Maybe if I should fix that, but that will change a little bit how textured curved walls in existing files are rendered...
YGYL, maybe I'll add dimensions in the 3D view one day, but I'm not sure it's so useful, and there's even no Dimension line modification dialog box yet!
I thought about displaying polylines vertically too, but this would imply to have also a global angle on each poyline (like for text), and this idea looked too weird for me.
Attachment RoundWallsWith360Texture.sh3d (358789 bytes) (Download count: 212266) (Test of a 360° texture applied on round walls showing a full circle)
[Sep 15, 2018, 12:35:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
