Total posts in this thread: 7
Previous Thread This topic has been viewed 16369 times and has 6 replies Next Thread
ELITE83
Transparent wall
Request:
make the ability to set the transparency for the walls.
need manual transparency level from 0 to 100%
this is to allow for a 3D plan is more convenient positioning of objects.
[Note from moderator: removed Russian translation]
[Edit 1 times, last edit by Puybaret at Feb 6, 2017, 1:32:28 PM]
[Feb 6, 2017, 1:05:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Transparent wall
What about using the Walls transparency slider available in the 3D view modification dialog box?
[Feb 6, 2017, 1:38:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
ELITE83
as a simple option - for all the walls in the 3D dialog.
but it is better in the properties dialog for the selected wall wall. to make transparent (translucent)
[Feb 6, 2017, 2:43:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Wall dialog box offers already a lot of options, and I don't think this additional option is interesting enough to add it.
[Feb 6, 2017, 3:47:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
gibs75
Transparency may be added into color dialog box / texture import ?
Playing with wall transparency individually (at the opposite of 3d view settings which is global). Transparent walls can be a way to work around lack of roof modeling.
[Dec 23, 2019, 12:12:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gian1
Can one make walls transparent on the 2D plan? The only way I can is by clicking and holding on them, but I would like to see the portion of the background image covered by walls without having to click and hold on them, lest I move them inadvertently.
[Apr 15, 2020, 7:00:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No you can't make walls permanently transparent in the plan.
[Apr 15, 2020, 10:49:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
