Posts: 44   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 296008 times and has 43 replies Next Thread
Re: Sweet Home 3D 5.3
..discussion about the evolution of the .sh3d format...
Interesting with the peak into the background thinking. Thanks for sharing the discussion. ok
[Oct 28, 2016, 4:24:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi Emmanuel
Just realised it is not only textures that are giving an issue. I have 2 items, a sliding door that i created in sh3d and part of a fire escape also created in sh3d, each time i open the prog they have reverted to thier original color. I can email you the sh3d file as it is quite small.
[Oct 30, 2016, 1:07:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please send the file to me.
[Oct 30, 2016, 1:55:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks Mike for your file and the description of your problems. I was able to fix the issues in the version 5.3 Beta 8.
This new Beta version allows to change again the angle of a texture and fixes an error during file opening that ignored the color of items which belong to a group. Unfortunately, this second bug provoked a loss of the color information of these items when the opened file was saved with the Beta 7. I hope you tried that Beta version on copies of your sh3d files as recommended, otherwise you'll have to change the color of the grouped items again.
Under Linux, the Beta 8 version should also fix a bug that grayed the 3D view when Sweet Home3D window was activated/deactivated. I didn't find yet why navigating in the 3D view runs slower than with version 5.2 under that system. More feedback and ideas on this point would be very appreciated.
Finally, this version 5.3 might contain only the .sh3d file format change and bug fixes. Some Windows and Linux users waited for corrections on critical bugs for quite a long time now, and I feel it would be better not to wait more weeks. Hope you'll agree.
[Edit 5 times, last edit by Puybaret at Nov 16, 2016, 11:09:36 PM]
[Oct 30, 2016, 4:55:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great work there Emmanuel, beta 8 works a treat. biggrin
[Oct 30, 2016, 8:48:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi Manu,
It works with the "fire of God" at home (french expression) and my signature is updated. applause
[Oct 31, 2016, 6:26:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dann
I'm a returning user and I thought I'd try the latest, so I downloaded the 5.3 beta8 jar to run on osx 10.10.5, java 1.8.0_45.
Everything seemed to be fine, I started editing a new plan, saved it and quit, but when I went to open it again nothing seemed to happen. I ended up running the jar from the command line with
> java -Xmx640m -jar SweetHome3D-5.3.beta8.jar
So that I could see if there was any console output to indicate a problem. And sure enough when I tried opening my file I got the following stack trace:
java.lang.NullPointerException
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1838)
at sun.misc.FloatingDecimal.parseFloat(FloatingDecimal.java:122)
at java.lang.Float.parseFloat(Float.java:451)
at com.eteks.sweethome3d.io.HomeXMLHandler.endElement(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:609)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumen
tParser.java:183)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentF
ragmentScannerImpl.java:1343)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2786)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragm
entScannerImpl.java:510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:333)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:195)
at com.eteks.sweethome3d.io.DefaultHomeInputStream.readHome(Unknown Source)
at com.eteks.sweethome3d.io.HomeFileRecorder.readHome(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$32.call(Unknown Source)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Reading this forum thread makes me suspect this may be due to the new file format, so I thought you'd appreciate the report. I can send you my file if that helps.
Dan
[Nov 3, 2016, 8:43:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback.
Dann, please send me your file. This should be helpful.
[Nov 3, 2016, 11:50:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks dann for your helpful file. You'll be able to open your file again with the version 5.3 Beta 11 and further.
This new Beta version fixes also two other bugs:
- Texture image files exported with OBJ file are copies of original image files instead of files generated from images in memory when available (see bug #686)
- The area of rooms are correctly computed when points draw a hole in its middle (see bug #681)
[Edit 4 times, last edit by Puybaret at Nov 16, 2016, 11:09:55 PM]
[Nov 4, 2016, 1:11:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dann
Thanks! Beta 11 opens my files.
[Nov 6, 2016, 7:48:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
