SH3D ne se lance pas sous (X)Ubuntu 14.04
Bonjour à tou(te)s
Ma machine fonctionne sous Ubuntu 14.04 (Trusty). Je réussis à installer Sweethome3d visiblement sans problème via la logithèque, mais lorsque je clique sur l'icône de lancement, rien ne se produit...
Java 3D: implicit antialiasing enabled Java 3D ERROR : Unable to query GLX version GLX version 1.3 or higher is required Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createView3D(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController3D.getView(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.createActions(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$4.collectionChanged(Unknown Source) at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source) at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.showDefaultHomeFrame(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.start(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$5.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:312) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:733) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:694) at java.awt.EventQueue$3.run(EventQueue.java:692) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:703) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
donc a priori - je suis nul en console, code et autres terminaux hein :) - un problème de Java... sauf que Java est bien installé sur ma machine...
Quelqu'un aurait-il une idée pour m'aider à utiliser ce super soft sur Ubuntu ?
Re: SH3D ne se lance pas sous (X)Ubuntu 14.04
Ca ressemble à un problème de driver de carte graphique. Pouvez-vous essayer avec la version proposée ici?
Bonjour,
j ai teste SH3D sur un 1.3ghz 512mo ram geforce 5200 sous lubuntu 14.04 (il n y a que l interface qui change) j ai fait la mise a jour du bureau vers xubuntu (xubuntu-desktop) et installe le pilote proprietaire nvidia 173 pour ma carte (telechargé en passant par synaptic et en modifiant les listes de depot sinon je ne le voyais pas) ensuite dans le menu pilotes additionnels il te liste enfin le pilote proprietaire je l ai donc installe puis redemarre la machine. cela me fait beneficier de l opengl
avant sweethome se lancait mais la fenetre de visualisation 3d ne m affichait que des barres multicolores (la fenetre en bas a droite) avec opengl active sur le driver proprietaire c est ok ! chouette
a tout hasard pourrais tu mettre ta config ? processeur ram et carte graphique ? a noter que j ai telecharger sh3d par la logitheque ubuntu en mode graphique et que je lance le logiciel en mode graphique
je ne pense pas que ce soit lie a des problemes de dependances mais sait on jamais ? ah eventuellement mais je n y crois pas il faudrait demander... sh3d gere t il le muticore ? si oui combien ? ton systeme est il en 32 ou 64 bits ? moi test en 32bits simple coeur
quand j ai un doute j essaie en mode live cd (mais je ne sais pas si tu peux alors installer le pilote proprietaire ?) ca me permet de savoir si j ai pas louper quelquechose entre le virtuel et le disque dur
voila si ca peut aider
et enoooorme merci a "toute" la communaute pour ce soft genial !!!
desole
oups en 3e ligne de ton post
glx 1.3 ou plus haut est requis et ca concerne bien l opengl ! ahah !!! 1/ peut etre un sudo apt-get install glx 1.3 (grosso modo hein) 2/ ou installer le pilote proprietaire ou bien faire les 2 ?
en 2e ligne de ton post on lit que java est incapable de "query?" le GLX
je mettrai donc a jour ce fichier glx au moins en version 1.3 voir plus ! et j installerai le pilote proprietaire pour avoir l opengl avec un peu de chance ca devrait fonctionner
