Posts: 22   Pages: 3   [ Previous Page | 1 2 3 | Next Page ]
Previous Thread This topic has been viewed 10887 times and has 21 replies Next Thread
Re: Rendering problem
Your timezone / longitude values aren't homogeneous. At 11 AM in Taipei, it's dawn at a longitude/latitude set in Europe, and the result is correct for these parameters.
[Edit 1 times, last edit by Puybaret at Sep 30, 2011, 3:47:46 PM]
[Sep 29, 2011, 10:21:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quickmic
I also have render problems. Some pixel-error can be seen... Here:
https://rms-systems.homelinux.net/download/Transfer/Pic.jpg
[Sep 30, 2011, 2:32:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Quickmic,
Can you use a TRUSTED website to host your images?
Firefox refuses to open it.
[Sep 30, 2011, 3:23:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quickmic
I don't wanna pay für an official cerificat but you can ignore the warnings... Else use this:
http://www.megaupload.com/?d=G05R2AW0
[Sep 30, 2011, 3:27:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You may want to have a look at www.mediafire.com ....
But even with the black spots, it's a VERY nice image!
[Edit 1 times, last edit by hansmex at Sep 30, 2011, 4:39:01 PM]
[Sep 30, 2011, 4:36:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
devilbliss
Ah ok emmanuel, thanks! Sorry for overlooking the timezone values, im not familiar with those. But its really cool that you've incorporated the timezone values in rendering photos in the program.
[Oct 1, 2011, 2:26:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
devilbliss
Nice quickmic! where did you get the wooden planks that you used for your room? thanks!
[Oct 1, 2011, 2:35:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's an other reason why you should choose the default photo rendering dialog of Sweet Home 3D v 3. It uses some code able to best guest your longitude/latitude for your default time zone, but the older Advanced rendering plugin doesn't use it (and I don't think I will update this plug-in).
[Oct 1, 2011, 8:33:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quickmic
Thats just normal textures. I loaded picture templates from the Web and modified them. The Trick is, that you must make sure that the Textures don't have borders if they are merged. -> If you found a nice picture, modify it by mirroring in any directions. Here are some of mine.
[Note from moderator: removed link to quickmic's textures library since he's not sure they can be redistributed]
[Edit 1 times, last edit by Puybaret at Oct 1, 2011, 10:22:28 PM]
[Oct 1, 2011, 6:41:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quickmic, I don't want to be boring and appreciate your will to share your findings, but did you check you have the right to redistribute these images before posting them?
[Oct 1, 2011, 6:56:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
