Re: Can we make a similar floor plan with our Sweet Home software?
Sudha,
There's no reason why you couldn't make something very similar with SH3D. It only takes: - the time to really learn the program - the right models for your furniture - the right textures for your surfaces.
You would then have to try out how to render the photo, playing a bit with the illumination.
Nepal
its quit easy to make the image like that just decrease the height of the walls or just make them transparent place all the furnitures adjust some lights create advanced rendering photos there the image is nicer then the one you have seen.....
Here are some pictures i did just in short time use nice furnitures and place lights properly to get amazing snaps this image is created using advanced rendering plugin!
Sudha,
If you use version 2.6, you can install the AdvancedRender plug-in. See the tutorial.
If you use version 3.0, the functions of that plug-in have been integrated into SH3D, so you don't need the plug-in. However, would you prefer the plug-in, it still can be installed, and is working correctly.
