Hommage to Light
Hello all :-)
To honour all the hard work of David, Frederic and Emmanuel to make the excellent Advanced Render plug-in (and function in version 3.0) I would like to share this "Hommage to Light" :-)
Re: Hommage to Light
Sebastien,
Unfortunately I can't send you the original file. SH3D crashed or something and the file was damaged in such a way that it could not be recovered. Therefore I couldn't submit it for the contest, so I decided to show it here.
How was it done?
Basically it is very, very simple. Two parallel walls with floor and ceiling, everything white or very light gray. The ceiling has fins, or blades of approx 50 cms high, spaced 50 or so cms apart.
Between the blades I placed approx. 150 light bulbs carefully tuned to produce this effect. Because of the large number of lights, each rendering took quite a long time.
That's how I did it in a nutshell.
EDIT: Taken away French translation
[Edit 1 times,
last edit by hansmex at Oct 14, 2010, 9:59:19 PM]
