Kenya
Hi Thanks for a great editor. At last i can get some order in my library :) I have one problem though, i cant open the furniture library, i get a message about that it's not a valid SH3F file, i also get that when the file i exported (all imported objects). I don't know if it, for some reason above my knowledge, is supposed to be like this.
If it's not, it could be my fault as i, in a dark moment, added a folder with a swedish letter ( ö ), can it be that? Especialy that folder creates a problem as the last of the objects in that can't be moved or deleted.
This is just giving the usual rectangular hole. I've followed the instructions in the PDF - is there something that is missing there or out of date?
I've also tested with L code, e.g. M0,0 L0.5,0 L0.5,0.3 L0.3,0.3 L0.3,1.0 L0,1.0 L0,0 which works just fine in an SVG file, but again, not in an SH3D file. Any ideas?
I just tried both shapes under Ubuntu 18 and macOS 10.14 and they worked as expected. Did you try with Sweet Home 3D version available at SourceForge.net?
United Kingdom
That's encouraging, so I spent another hour trying everything possible to produce an L-shaped hole in the ceiling for my staircase - without success. I've tried VH encoding, L encoding, my required measurements, the example measurements and a simplified rectangular hole - all to no effect. Always, the ceiling hole is the full rectangular base dimensions. It is not possible to make it smaller. The SVG encoding seems fine. It looks like a bug at the moment. Maybe because the design file is too big? I'm at a loss to explain this lack of custom hole ability.
I'm using the latest version of SH3D, i.e. 6.5 and I've looked inside the SH3F zip file and the SVG line is preserved as expected.
Can you see if you can make an L-shaped hole in this SH3D file with this SH3F staircase?
Romania
Few advises: 1. When you make staircase in real life watch your head! That's why:
Look at the head of man (184.5cm tall) Unfortunately I've see this in real life.
staircaseCutOutShape#1= M0,0 v0.645 h0.5 v-0.382 h0.5 v-0.258 z
The second:
staircaseCutOutShape#1= M0,0 v0.789 h0.5 v-0.532 h0.5 v-0.258 z
2.For a precise cut out you have to make some calculations
- the red lines represent cut out - to calculate you need to divide the needed dimension to total dimension (vertically or horizontally) For second cut out to find first v0.789 I do 300/380 and so on.
3. When use Furniture Editor and modify a furniture move the preview a little until the program take a new shoot. In this way you avoid the dark background.
5. In future you will have to learn how to make round corners. Good luck
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
United Kingdom
Really appreciate the work you've done on this and I understand about stair heights, but the file you created when imported into my version of SH3D it still does not create an L-shaped opening, just the usual rectangular opening. If the L-shaped opening works for you, then the file is fine and it must, therefore be either: * SH3D program (v6.5 on Linux) has a bug * I'm doing something wrong with the furniture import (I choose "Staircase")
