Re: Lower object above stairs in 2D.
The desk wasn't lower, it was at the same elevation as the stairs (0). But you probably added the desk after the staircase which means it shows over the the staircase. Instead of elevating the staircase with 1mm you can cut&paste the staircase and thus placing it higher in the order in which objects are added to the list. Objects show in the order they were added if they are on the same elevation. This works the same when you group objects: the last selected to group shows over the other objects you group.
[May 8, 2024, 6:12:57 AM]
[Link]
