Plugin location
Greetings...just downloaded Sweet Home 3D today. Also downloaded AutoDimensioning.shp3. The plugin appears to work fine but wondering where it should reside in the PC? It currently sits in the download directory...thanks Bob
Re: Plugin location
When you open the plugin with SH3D it is magically saved into the applications plugin folder. Where this is located depends on which OS you are using. You can remove the file in the Downloads folder, as it is not used once SH3D has copied to the plugin folder.
