United States
How do l ...
1. How do I lower the pool into the floor to make it an inground pool? I tried doing a negative elevation, but it didn't work. 2. What am I doing wrong? 3. Also. How do Raise the ceiling/wall height of the bottom floor without it intersecting or coming into the top floor?
Do villains see themselves as saviors, as would a hero? Based on the fact that most comic book villains (e.g: Marvel/DC) their motives are that they are trying to save or right some wrong. So are they really villains, anti-heroes or Anti-Villains?
United States
Re: How do l ...
I tried help it did not help. Doe that mean that I will have to delete the already build top floor?
United States
Re: How do l ...
What do I do if I want to lower a room into the ground?
Re: How do l ...
Did you read my last post? Check the last url I gave about "how to add a basement". Basically, you add a level with a negative elevation where you can draw walls and add a floor to get a room below ground level.
