Total posts in this thread: 5
Previous Thread This topic has been viewed 236 times and has 4 replies Next Thread
MatheusNegrini
Brasil
How i can change my texture brick color?
Hi people, i need change a texture brick color, like a brick change a color to white (for example) but maintein the texture of the brick, if i trie set a texture and change a color in "switch walls" tool, the wall chage your's texture, i need maintein the texture
[Jan 29, 2024, 1:43:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How i can change my texture brick color?
A texture is an image that is applied to the wall. To change the color of the texture you will have to change the color of the image.
If you don't have the texture image as a file you can export the wall. One of the resulting files that is created is the texture image. Modify the image with a program like GIMP and import it as the new texture for your wall.
[Jan 29, 2024, 4:37:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MatheusNegrini
Brasil
Tanks i will try it, have a nice day!
[Jan 29, 2024, 5:24:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe this blog's article will help you: http://www.sweethome3d.com/blog/2016/01/31/ho..._colors_of_a_texture.html
[Jan 29, 2024, 8:06:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
captaincook
Bonjour.
Vous pouvez aussi regarder sur ce site si vous trouvez ce que vous cherchez. Exemple pour des briques blanches.
https://www.sketchuptextureclub.com/textures/architecture/bricks/white-bricks
Le choix de textures en tous genres est énorme.
Le téléchargement est gratuit pour la plupart. Il faut juste se créer un compte.
[Jan 30, 2024, 12:24:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
