Brasil
How i can change my texture brick color?
Hi people, i need change a texture brick color, like a brick change a color to white (for example) but maintein the texture of the brick, if i trie set a texture and change a color in "switch walls" tool, the wall chage your's texture, i need maintein the texture
Re: How i can change my texture brick color?
A texture is an image that is applied to the wall. To change the color of the texture you will have to change the color of the image.
If you don't have the texture image as a file you can export the wall. One of the resulting files that is created is the texture image. Modify the image with a program like GIMP and import it as the new texture for your wall.
