Australia
Better quality background image
Is there any way to increase the image quality retention of a background image import? I have noticed a significant drop in image quality when I import.
Re: Better quality background image
If you observed this on the Online version, it's on purpose because resources on server are not extensible to infinity.
Australia
I am using a local version. Normally it's not much of an issue as long as I have the walls as a guide, it's just that on my current floorplan they drew the doors with very fine lines and when I import the image into SweetHome the door lines are no longer visible. I can understand it might be compressed or stretched and that will reduce quality I was just wondering if there was a way to override it to keep original image quality at the cost of making my file larger.
Romania
Try to change the background (or reload) and don't let the program to reduce the size of the image.
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
