Re: automatically open .sh3d file on a Mac
The associations between an application bundle and the files extensions is indicated in the UTExportedTypeDeclarations section of its Info.plist file. Look at the one of Sweet Home 3D,, it's self-explanatory.
On macOS, Sweet Home 3D is bundled with Zulu 15.0.10 as indicated in its Ant project file.
Bundling Zulu 15.0.10 with Sweet Home 3D makes it able to run on macOS from 10.9 to 14.
FR
Hi
On my PC with Oracle Java 15.0.2, when I build the officiel SW7.1 source, I obtain the following messages:
[echo] compiling Sweet Home 3D for Java 1.7 minimum version [mkdir] Created dir: Desktop\SweetHome3D-7.1-src\build\classes [javac] Desktop\SweetHome3D-7.1-src\build.xml:68: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds [javac] Compiling 2 source files to Desktop\SweetHome3D-7.1-src\build\classes [javac] warning: [options] bootstrap class path not set in conjunction with -source 7 [javac] warning: [options] source value 7 is obsolete and will be removed in a future release [javac] warning: [options] target value 7 is obsolete and will be removed in a future release
But, on my mac (13.6), using Zulu 15.0.10 (Zulu 15.46), I obtain two errors: [javac] error: source option 7 is no longer supported, Use 8 or later [javac] error: Target option 7 is no longer supported, Use 8 or later
