Daniels118
Italy
Re: Objects not coloring correctly in render
I think he is talking about the wrong triangles shown on the ground, this is the fixed link to the image:
This may have different causes, all belonging to the model: - z-fighting between close poligons; - wrong faces orientation and backface culling turned on; - wrong vertex normals.
I think you are using a furniture to represent the ground. Try instead to use a room, apply the texture and scale it to match the room size. If you want to use a furniture, try with a standard cube, scale it properly and apply the texture on the upper face.
[Jul 9, 2023, 10:29:21 AM]
[Link]
