Re: running source code in eclipse
Did you follow the instructions in the README.TXT file of SweetHome3D project?
Select com.eteks.sweethome3d.SweetHome3D as main class. com.eteks.sweethome3d.SweetHome3DBootstrap is made to be run from a JAR executable or Applet / Java Web Start environment.
FR
Hi I have some problems with openJDK15, GUI is not refreshing correctly, some buttons are placed incorrectly, windows screen update is done partially.
So I suppose, I will install the last version of the JDK to run the app. Nevertheless, I need to compile with an older version. Which jre version do you recommend to run SW 7.1 in eclipse ?
I mainly use Eclipse under macOS so I'm not sure my advice will interest you. Anyway the best advice is to follow Eclipse recommandations. It's also possible to install more than a JDK in your system and use them in Eclipse. At this moment, I have 5 different JDKs/JREs configured in my Eclipse installation.
I am currently using the latest version Eclipse and jdk
i am running the code with com.eteks.sweethome3d.SweetHome3DBootstrap as the main class with the arguments -classpath lib/java3d-1.6:<other_directories_or_jars> -Djava.library.path=lib/java3d-1.6/macosx -Djogamp.gluegen.UseTempJarCache=false as i am using mac
i am getting the following errors 2024-04-03 14:26:14.327 java[1597:45750] WARNING: Secure coding is automatically enabled for restorable state! However, not on all supported macOS versions of this application. Opt-in to secure coding explicitly by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState:. Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/opengl/GLCapabilitiesChooser at java.base/java.lang.Class.forName0(Native Method) at java.base/java.lang.Class.forName(Class.java:375) at javax.media.j3d.Pipeline$1.run(Pipeline.java:162) at java.base/java.security.AccessController.doPrivileged(AccessController.java:318) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:157) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:965) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299) at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:351 ) at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Component3DManage r.java:112) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:83) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:160) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:642) at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:467) at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:370) Caused by: java.lang.ClassNotFoundException: javax.media.opengl.GLCapabilitiesChooser at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:641) at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525) ... 14 more
This repository is not official and apparently not maintained. Use the repository at SourceForge.net or a source code archive, and be sure to read the README.TXT included file.
