Italia
Rendering con la luce diurna in "Vista Aerea"
Hi, I can't render with daylight in "Aerial View" and ceiling enabled. If I Render the room in "Virtual View", the sunlight reflects correctly on the walls through the windows but, if I do it in "Aerial View" with the ceiling active, the sunlight passes from above illuminating everything. How should I do to have the correct illumination of the sun in the rooms in the "Aerial View"?
