Display in Separate Window as own instance, or...
The Display in Separate Window (crl+alt+Y) opens a new window, but I cannot switch between main window and this window. Is that normal? I use WIN10, latest updates and SH3D V7.0 (for V6 it is the same)
Using on 2 monitor workstation is fine, but it is not an advantage at PC with only 1 monitor. So pefect would be to have this window as own instance, to be able to switch with the usual windows shortcuts (ALT+TAB) OR to integrate some shortcuts in SW3D, to be able to change the size of the areas. Instead of pushing with the mouse, jus a fast shortcut, would help me much. As I guess, this can be done only if some presaved workspace layouts can be used, this wuold be my wish of today ;-)
