Text menus are blank/white
Hello I installed version 2.1 on my home computer ( because it was working very fine at work) the program starts normally and I have all the menus and the buttons, but if I click on 'file' for example on the text menu bar, it rolls down a white menu, nothing inside. The functions are appearing and disaprearing if I pass the cursor trough the menu, but it remains blank if I dont move. If I use the functions they work, but it is quit embarassing to have all the menu content white.
Re: Text menus are blank/white
I never heard about this problem. On what system are your running Sweet Home 3D? What Java version do you use (see Sweet Home 3D About dialog)?
I will try to make a snapshot of the screen to let you figure out. I am on a standard win XP computer, I am at work for the moment and the computer is at home, I don't know my adobe version but I will check it tonight and let you know
I am having the same problem. I am also a newbee. I am running XP with the latest MS updates with Java 6.0.170, & NVIDIA Gforce 8600 GT. I also have a problem while working on a plan view. Periodically additional graphic boxed are displayed over the top of my working image. When I save the file and close the program and restart everything works fine for a while.
