Total posts in this thread: 77
Posts: 77   Pages: 8   [ Previous Page | 1 2 3 4 5 6 7 8 | Next Page ]
Previous Thread This topic has been viewed 86508 times and has 76 replies Next Thread
Daniels118
Italy
Re: Wirings plugin
Version 4.1.1
  • Fixed thickness bug
  • Fixed the bug happening when editing with Advanced editing plugin
  • Fixed the toolbox window not opening. Thanks to Andrey for reporting the bug.
Download from SourceForge or using the Plugin Manager.
[Aug 4, 2022, 5:05:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wirings plugin
I found a funny bug, at least on Debian Linux.
When I have the help window open for the wirings plug-in and close Sweethome3D the help window remains open and can't be closed. You have to kill it the hard way by killing the Java process.
[Aug 25, 2022, 3:23:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Re: Wirings plugin
Hi Keet,
thank you for reporting this bug, unfortunately I cannot reproduce it on my Windows machine, moreover the help dialog is the same used by the main program so I have few chance I can fix it.
I'm curious, does this happen only with Wirings plugin help or even with the SweetHome3D help window?
[Aug 26, 2022, 3:46:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wirings plugin
I tried it with the Sweethome3D help window and that closed when closing Sweethome3D.
So I tried it again with the Wiring help...
and this time it closed when I closed Sweethome3D. The only difference was that I had a really huge project open when the 'bug' occurred and this last time it was a very small project. I'll regard it as a weird fluke on my system and not a bug in the Wirings plugin.
[Aug 26, 2022, 11:16:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
Re: Wirings plugin
How does one get this Plugin?
It's not in the List ?
Regards Graham
[Aug 31, 2022, 4:38:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wirings plugin
It’s indicated in some posts of this thread that I encourage you to read from its first post.
[Aug 31, 2022, 7:56:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Re: Wirings plugin
First: install this plugin
Second: You have to install and learn how to use more others including wirings plugin
I knew you are somehow impatient but you have to learn more basic.
I appreciate only 1 month of learn and work with this program (in your case) to evolve from newbie to advanced.
I could help you!
[Aug 31, 2022, 7:56:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
Re: Wirings plugin
You are helping me and I am extremely grateful, thank you.
Regards Graham
[Sep 6, 2022, 7:01:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shoulders
United Kingdom
Re: Wirings plugin
On this old sourceforge issue a user asked about "It would be useful to print a wiring only preview of the house in 2D/3D.", this could be a useful feature.
https://sourceforge.net/p/sweethome3d/feature-requests/33/
Also (and I am being lazy here) is there an option to add wiring conduits and perhaps these could surround the wires?
[Oct 21, 2022, 3:09:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Re: Wirings plugin
This can be achieved by using levels as layers. You add another level at the same elevation of the current one (let's call this new level "wirings layer").
Then, while keeping the wirings layer selected, draw the wirings using the plugin. If you have already placed wirings on the wrong level, select them, use the cut tool (ctrl+x), then select the wirings layer and use the paste tool (ctrl+v).
Now you are able to hide/show independently wirings and/or the rest of the home.
NOTE: to take a picture of the 3D view with wirings visible, you can't use the photo tool. You have to capture the screen using any tool provided by your operating system. This is a known limitation.
This was an old idea I had in mind, however I have not defined a plan to implement this feature. It certainly won't came in the next release, but it could in the following one.
[Oct 22, 2022, 6:05:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
