Fresh install, have not used application before. Started at version 6.6a however issue still occurs on version 6.5.2a, which fixed a similar issue last year according to other posts on this forum.
I can't find any logs that seem useful - please let me know if there is any way I can assist in troubleshooting the problem.
Re: 3D import on M1 MacBook Air crashes SH3D
Aaron, if you use the Mac App Store version, run it with Rosetta. Otherwise, use the special version available at https://www.sweethome3d.com/downloads/SweetHome3D-6.6-macosx-jogl-2.3.2.dmg which runs with an older version of JOGL. As this version can't be notarized, you'll have to launch it the first time by clicking on Sweet Home 3D icon while maintaining control key pressed and choosing Open item.
Camerone, try this special version too.
United States
I am also having this issue with 7.0.2 on a Mac Mini M1, can confirm that the 6.6 special version does work on imports. What I ended up doing before was import using the online version and then save and open up the file using the desktop version.
