Member(s) browsing this thread: honzare
Posts: 248   Pages: 25   [ Previous Page | 10 11 12 13 14 15 16 17 18 19 | Next Page ]
Previous Thread This topic has been viewed 636660 times and has 247 replies Next Thread
upsetter21
Re: Generate roof plugin
Hello:
the GenerateRoof Plug-in shows up in my Tools menu, but when I click nothing happens.
I've been trying to figure out how to put a roof on my project for weeks.
Today I am finally going crazy!
[Jan 26, 2023, 8:03:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Probably it appear grayed.
Select a room and try again.
[Jan 26, 2023, 8:26:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Follow STRICTLY this steps. I will not writing twice.
1. Open a new file, draw approximately your walls (it is only for learning so, the accuracy is not so important).
2. Draw a room around walls which represent the roof projection.
3. Select that room
4. Tools -> Generate roof...
5. You should see something like this
6. Select the triangle faces (4 in this case). Keep Ctrl pressed to do this.
7. Set their slope to 90 degrees
8. Check the Invisible checkbox
9. Select two faces in front of the house
10. Set their slope to 33 degrees
11. Do the same with faces from the back side of the house
12. Click somewhere outside the roof and you should see this. Click OK.
13. On plan, Right click on selected roof and go to Modify furniture... -> Materials -> Modify...
14. Select all upper faces
15. Set their texture
16. Select border and lower
17. Set preferably a different texture
18. This could be the result
If you are not completely satisfied with the result you could select the generated roof and go back to Tools -> Generate roof.
The plugin it is able now to do this thanks to Daniels118.
[Edit 1 times, last edit by dorin at Jan 27, 2023, 8:37:25 AM]
[Jan 27, 2023, 8:03:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Whaou, Dorin, thank you very much, it is very clear!!
[Jan 28, 2023, 12:28:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Vinci68
applause Re: Generate roof plugin
Thank you Dorin for your patience in explaining, in great detail, how these plugins work. It helps a lot of beginners... like me!
[Jan 28, 2023, 11:59:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Thank you VeroniQ and Vinci68!
Probably you two are the only one who read it all.
Mainly those who don't need more explanations (VeroniQ).
The rest of the people stop reading at point 3 or 13.
It appear it is a YAUT (Yet Another Useless Tutorial).
[Jan 28, 2023, 8:42:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Definitely not a useless tutorial. You have to understand these basic steps before you can start with more complex roofs and start to combine different roofs if a single roof is impossible.
Good work!
[Jan 28, 2023, 9:01:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
Hi Dorin,
i would like to do a 5 degree slope, but roof generator starts at 15.
How can i do it
[Jan 30, 2023, 8:51:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
You can't now.
We work on this so, in the next version, we hope it should be possible (from 1~179).
We still testing it.
[Jan 30, 2023, 9:18:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
nah, I red it and appreciate a lot, even if I already used the plugin with success, i found an additional step i wasn't doing.
Unfortunately I'm one of those who reads everything but rarely comments, so sorry for that, but your work is a high level one and really appreciated. I suggest to save it as a PDF, put it online and add in the plugin notes/description so the ones using plugin manager can see a "GUIDE" immediately!
Thanks for your development and infinite patience.
[Feb 2, 2023, 8:01:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
