Schweiz
Re: Freeze when opening a model
I was able to narrow done the problem: - it occurs with V6.5 too - it occurs when I start the application and try to open a model (any model), which I created earlier
And I found out, how to open a "old" model, but it is a bit strange: 1. Start the application 2. Save the empty model which appears when starting the application 3. Open an old model --> and the it works
So, the problem is not high priority anymore, but I don't know how to get rid of the exclamation mark. May a moderator can do it.
The question is, why can't I open a saved model just after starting the application? Thanks.
Please try the special version available at http://www.sweethome3d.com/downloads/SweetHome3D-6.6-macosx-jogl-2.3.2.dmg which runs with an older version of JOGL. As it can't be notarized, you'll have to launch it the first time by clicking on Sweet Home 3D icon while maintaining control key pressed and choosing Open item.
Basically the issue makes the software unusable on MacOS.
Please don’t over exaggerate the problem. Many users don’t have this problem (me included) and many people don’t import 3D models. By the way, as far as I know, Sweet Home 3D can’t work with Java 17 yet, and it’s bundled with Java 15.
