Re: Transparent floor
Here's my suggestion: - Create a new home - Choose Plan > Add level menu item - Select room creation tool and draw the shape you want - Choose 3D view > Modify 3D view menu item and select the transparency level you want with Walls transparency slider - Choose 3D view > Export to OBJ format and confirm the option Export selection when prompted - Import in your main home the exported OBJ file with Furniture > Import furniture menu item
Finland
Hi, thanks for the hint, yes this solution works; there is any additional possibility just to assign to the floor the glass material similarly to the windows object? Thanks
Excelent! Worked perfectly and saved me an hours trying to get it to work in blender.
Who said you can't do it. I don't listen to Who anymore.
Personally I find it easier to edit the exported object and add a d value (transparency) to the material I want to be transparent. In most cases you only want one part to have transparency and with the manual edit that's just as easy.
