Total posts in this thread: 5
Previous Thread This topic has been viewed 3360 times and has 4 replies Next Thread
Clamarc
Brazil
Imported furniture
I imported a furniture, door handle, in .dae format and checked the option to add to the catalog. I was wondering where this furniture was saved, because when I open the furniture catalog at C:\ Users\xxxxx\AppData\Roaming\eTeks\Sweet Home 3D\ furniture, the furniture is not in the file forniture.sh3f nor in the file contributions.sh3f! ... where was the furniture that was imported saved?
Thanks
Clamarc
[Mar 16, 2021, 6:44:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Imported furniture
They are stored in .pref files.
[Mar 17, 2021, 2:02:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Clamarc
Brazil
hi, Puybaret
But aren't they converted to .obj if I want to make a change to the file?
thanks
Clamarc
[Mar 22, 2021, 6:47:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Imported 3D models are not always converted to OBJ format. The content of ZIP files are not modified for example. But you shouldn't rely on this because it could change one day, the reason why files are suffixed by .pref to avoid users changing them.
If you want to edit a 3D model at OBJ format, you should rather import it then export it with the 3D view > Export to OBJ format menu item.
[Edit 1 times, last edit by Puybaret at Apr 1, 2021, 6:29:06 PM]
[Mar 22, 2021, 10:45:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Clamarc
Brazil
Thanks Puybaret!... it helped me a lot!
Thanks and congratulations for the work!
Clamarc
[Apr 17, 2021, 1:11:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
