Total posts in this thread: 2
Previous Thread This topic has been viewed 4028 times and has 1 reply Next Thread
crackwood01
Canada
BiFold Doors in frame
How can i set the propertie or what can i write in the mtl file to be abe to create a bi-fold door in a door frame.
right now i'm using a door frame with bi-fold door that i drag inside the door frame, but i would like to create a obj file that could be working, right now, when i create the obj file, he weight of the door change when i insert it into a wall and i get a piece of wall in the middle of the 2 doors.
Here is a link to the file
http://crflix.ca/Doors.sh3d
[Nov 16, 2020, 2:00:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: BiFold Doors in frame
There are two problems with your bidold doors.
1 - The door frame doesn't have a "bottom", therefor it's open and the wall will fill the cavity it should cut out of the wall.
2 - In the OBJ file, the door frame and doors are not described as separate entities, therefor the door will flatten when inserted into a wall.
The solution for the first problem is simple. Insert the door into your wall using the arrow keys, not the mouse. This prevents the doors from flattening. See attached file.
The second problem can be solved as well, but is more tricky. You have to delve into the object properties and change a few things. To be honest, I'm too lazy to find out how and where, but the information can be found in the forum.
example file
[Nov 16, 2020, 11:04:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
