Total posts in this thread: 4
Previous Thread This topic has been viewed 5624 times and has 3 replies Next Thread
Doublebass
Deutschland
Wände verbinden
Hi all,
when you make a room by walls, they often do not really "connect" properly.
(They do if you make the room by building all they walls at once, clicking only one time after each part is done. But sometimes, this is not an option.)
How it is:
https://ibb.co/qRB1Kty
How it should be:
https://ibb.co/Y0xNzgx
I made the 2nd pic by manually stretching the upper wall, making it long enough to start exactly at the position of the other wall.
But this cannot be the appropriate solution? It can easily be messed up by unprecise drawing.
There must be a way to "close" the wall automatically??
[Edit 1 times, last edit by Puybaret at Aug 19, 2020, 10:42:42 AM]
[Aug 18, 2020, 8:18:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wände verbinden
You should have double-clicked at the end of the last wall, or afterwards, you may select the walls to join and choose the menu item Plan > Join walls.
[Aug 19, 2020, 10:45:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Doublebass
Deutschland
Re: Wände verbinden
or afterwards,
That didn't work, repeatedly.
Then I repeated trying it even more, then it worked... thinking
Thanks!
[Aug 19, 2020, 9:31:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wände verbinden
https://www.youtube.com/watch?v=ezVttM5xd1A
[Aug 19, 2020, 9:45:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
