Previous Thread This topic has been viewed 3077 times and has 10 replies Next Thread
Error in sh3d 6.4 with old projects ?
I saw a problem with the new version 6.4 and the old projects (<= 6.3).
In the given project, open it and try to join wall 1 and wall 2... a problem ?
Link
Try to join wall 1 and wall 3... no problem !!! strange.
NB : the base (Lvl 1) hasn't this problem, only the Lvl 2.
Why ? biggrin
Remark: this project has simple walls and 3 texts box, there is no object and the compressed file weights 1.94 MB.
Why ?
I didn't see any problem with new file (6.4). wink
[Jul 31, 2020, 1:27:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Error in sh3d 6.4 with old projects ?
The error happens in version 6.3. Very strangely, the wall 2 is joined to itself at its start. I wonder how that could happen, and if you find a way to reproduce this issue, I would be happy to know it so I can fix it.
The size of your SH3D file comes from the texture image you used for the ground.
[Jul 31, 2020, 3:02:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Like I said, I updated an old project (6.1.2) and I saved it under 6.4.
I closed sh3d then I re-opened the project, the walls (not all) became unjoined...
OK, TY. wink
[Jul 31, 2020, 5:52:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hum, it's not what I read wink
I just tried to reproduce your issue on a file created with version 6.1.2, but opening, saving and reopening it with version 6.4 didn't show any unjoined wall. There must be something else... sad
As the version 6.4 introduced more IDs on plan objects, I hope I didn't introduce a bug in the management of existing wall IDs.
[Jul 31, 2020, 6:35:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Apparently, the error is on a particular project.
I tested another old projects and they work fine in 6.4. wink
Mystery of softwares... biggrin
[Aug 1, 2020, 10:34:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If ever you kept a copy of the SH3D file before you updated in Sweet Home 3D 6.4, I'll be happy to review it.
[Aug 2, 2020, 10:06:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
OK, asap.
New : Some errors go on in new project in version 6.4 !!!
Again in joined walls which became unjoined after re-opening the file ???
crying
[Aug 3, 2020, 7:54:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
In waiting the update of 6.4, I return back to 6.1.2 ! biggrin
[Aug 6, 2020, 5:58:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I found the bug which happens when a wall is split in two walls, either with Plan > Split wall menu item or when you request to recompute walls in room modification dialog box. I fixed it and will probably release a version 6.4.2 soon.
[Aug 7, 2020, 6:29:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The version 6.4.2 was released tonight to fix this issue. This update won't join again detached walls, but at least, it will let you join them again and won't provoke this bad bug.
Thanks for reporting it.
[Aug 8, 2020, 9:29:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
