Brasil
Walls and floor are white on 3Dview
Hello guys,
I'm creating a planned kitchen in Sweet Home 3D and after open the project and change the vision in 3D everything change from grey to white like in the picture. (sorry for my english, i don't know very well). What could be doing this? Thank you!
Brasil
Re: Walls and floor are white on 3Dview
It's not, I verified it now. When I open the project, everything seems to be ok but when I move the 3D vision the bug happens (only if the "food elevator" is visible)
Brazil
Hello
I'm getting almost the same problem. All the floor and walls on 3D view are white now, suddenly I start facing this problem. Any idea what could be happening? I restart the software, but it didn't solve the issue.
I wonder if it would work better with Java 3D DirectX. To try this option, follow these steps: - If you use Windows 64 bit, relaunch the installation program of Sweet Home 3D and select the 32 bit architecture option in the screen used to choose the installation folder (if you use Windows 32 bit, just ignore this step) - Download the file SweetHome3D.l4j.ini and copy it in Sweet Home 3D installation folder (by default, C:\Program Files\Sweet Home 3D or C:\Program Files (x86)\Sweet Home 3D) - Relaunch Sweet Home 3D and check how it works (the About dialog should mention Direct X if SweetHome3D.l4j.ini is taken into account).
