Vertical start a wall above ground, how?
This topic has been viewed 3298 times and has 2 replies
Carrock
Country: Denmark
Post by Carrock »
Hi all
Anyone knows how to move a wall up?
What i need to do is to create the triangle in the top above a window when the wall below is not full height.
Below you can see the wall is not full height, but how do i then add a wall on top that covers the area above the window?
Thanks
Re: Vertical start a wall above ground, how?
1 - split the wall in two parts, and make both parts sloping
or
2 - insert a triangle
or
3 - insert a level with the correct elevation where you put a wall, split the wall in two parts, and make both parts sloping
Carrock
Country: Denmark
Post by Carrock »
Great, thanks
Adding a new level with a modified height made it work.
Users browsing this forum: Baidu [Spider], Semrush [Bot]
