This topic has been viewed 3120 times and has 2 replies
Thread status:
Active
Carrock
Posts: 2 Joined: Wed Feb 05, 2025 7:08 pm
Country: Denmark
Post
by Carrock » Wed Feb 05, 2025 7:18 pm
Hi all
Anyone knows how to move a wall up?
What i need to do is to create the triangle in the top above a window when the wall below is not full height.
Below you can see the wall is not full height, but how do i then add a wall on top that covers the area above the window?
Posts: 4031 Joined: Sat Sep 26, 2009 11:36 am
Post
by hansmex » Thu Feb 06, 2025 10:20 am
1 - split the wall in two parts, and make both parts sloping
or
2 - insert a triangle
or
3 - insert a level with the correct elevation where you put a wall, split the wall in two parts, and make both parts sloping
Carrock
Country: Denmark
Post
by Carrock » Thu Feb 06, 2025 8:24 pm
Great, thanks
Adding a new level with a modified height made it work.
Users browsing this forum: MSN [Bot] , Semrush [Bot]
