sad High priority How to rotate a whole map from vertical to horizontal
This topic has been viewed 3988 times and has 2 replies
Fred19732
Post by Fred19732 »
Hi everybody,
I built a house plan in a vertical position.
My question is : how can I do to rotate the whole map from vertical to horizontal without having to rotate each object of the map?
many thanks for your answers
MarioSambol
Country: Croatia
Re: How to rotate a whole map from vertical to horizontal
Post by MarioSambol »
Select all the objects, then group them. Now you can rotate everything in the group at once.
Daniels118
Country: Italy
Post by Daniels118 »
Unfortunately not all object types can be grouped. Luckily there are 2 plugins that can do this work:
- Advanced plan editing plugin
- Home rotator plugin
I encourage to try both of them, the first is more complete, but the second should be a lot easier to use for your use case.
