This topic has been viewed 4747 times and has 2 replies
Thread status:
Active
paddifly
Posts: 1 Joined: Sun Jun 04, 2017 6:07 pm
Country: Germany
Post
by paddifly » Sun Jun 04, 2017 7:37 pm
Hello,is it possible to create a wall, which is left side rounded vertical by a specified radius?? thanks for any solution [:)] .
Ralf
Posts: 4031 Joined: Sat Sep 26, 2009 11:36 am
Post
by hansmex » Mon Jun 05, 2017 4:46 am
1st method
- insert an invisible, insertable cylinder
- doesn't work because the cylinder makes a square cut in the wall, not a rounded one
2nd method
- draw a wall that has the desired curvature
- export and import it, rotating it 90 degrees
- could work for a straight wall, but will cause problems in corners
3rd method
- use another program
Sorry
Posts: 2614 Joined: Sat Mar 29, 2014 7:17 am
Post
by bdfd » Mon Jun 05, 2017 6:26 am
@hans,
4th method
- Maybe with a hollow cylinder and adjusting walls, floor and ceiling ???
=> It will be not easy ! [:D]
