Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Photo-video rendering plug-in |
| Print at Sep 14, 2026, 7:25:52 AM |
| Posted by enkonyito at Aug 4, 2022, 1:47:58 AM |
Re: Photo-video rendering plug-in The source code is also available here. ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Sep 4, 2022, 7:14:10 AM |
Re: Photo-video rendering plug-in PhotoVideoRendering-2.4 plug-in As EnkoNyito is not available at the moment to update his Photo-video rendering plug-in, I made the necessary changes to this plug-in to ensure its compatibility with Sweet Home 3D 7.0 lights defined from a shape with lightSourceMaterialName# property. Note that the YafaRay rendering engine included in this plug-in doesn't work with the Mac App Store version 7.0.1 and above for security reasons, but works with the free version. With the old YafaRay Rendering plug-in, you had to use the lib folder of the com.eteks.sweethome3d.plugin.yafarayrendering package to load the necessary DLLs. Sweet Home 3D 7.0, uses the "com.eteks.sweethome3d.j3d.YafarayPluginsFolder" system property which causes the error: Exception in thread "pool-9-thread-1" java.lang.UnsatisfiedLinkError: com.eteks.sweethome3d.j3d.AdvancedYafarayRenderer.createEnvironment(Ljava/lang/String;Ljava/lang/String;)J---------------------------------------- EnkoNyito |
| Posted by Puybaret at Sep 4, 2022, 1:30:53 PM |
Re: Photo-video rendering plug-in Sorry, I forgot to mention here that I released the version 2.4.1 to fix a bug reported by Captaincook about invisible lights which had no effect with SunFlow. EnkoNyito, I’m not sure what you want to do or what problem you encountered. Can you explain how you got the error you reported? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Sep 4, 2022, 8:33:55 PM |
Re: Photo-video rendering plug-in In version 2.4.1, the com.eteks.sweethome3d.plugin.yafarayrendering package containing the YafarayRenderer.java file is used to load the necessary DLLs. In Sweet Home 3D 7.0, the YafarayRenderer.java file (subclass of AbstractPhotoRenderer) is contained in the com.eteks.sweethome3d.j3d package. By not including the com.eteks.sweethome3d.plugin.yafarayrendering package in the plug-in and by using the new loading of the DLLs of the file YafarayRenderer.java of SH3D-7.0, we have the error above. By opening the default photo panel first, the error returned is: java.lang.UnsatisfiedLinkError: Native Library C:\Users\user\AppData\Local\Temp\com.eteks.sweethome3d.SweetHome3D-cache-yafaray-64-43014161-1659389236\libwinpthread-1.dll already loaded in another classloaderIs it better to use the DLLs present in lib/yafaray of SweetHome3D-7.0 or in com/eteks/swethome3d/plugin/yafarayrendering/lib of the YafarayRendering-1.4.5 plugin? ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Sep 5, 2022, 4:49:47 PM |
Re: Photo-video rendering plug-in It would be better to reuse the DLLs available in Sweet Home 3D in your plug-in, but then you'll get the error you reported. As removing these DLLs from your plug-in will prevent it to work with older versions of Sweet Home 3D, I think it's better to keep them with your plug-in for the moment. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by varigonda at Sep 15, 2022, 12:39:42 PM |
Re: Photo-video rendering plug-in My simple photo rendering is stopping in between without showing any progress. and when i stop the rendering then save button is not visible at this time (When it is stuck). i am using mac 10.12 , simple photo rendering 2.4.1 . after in progressed for couple of hours then it stuck then there is no way to retrieve photo it created. need help in fixing this issue . At least can you please let me know how to retrieve photo it created till that point. Below are setting i am using. 1) depth of field and best quality with sky light on. 2) below are advanced settings AA_minsamples 16 lighting method sppm normallens.radios 0.1 remaining all default settings. |
| Posted by YGYL at Oct 5, 2022, 6:59:27 AM |
Re: Photo-video rendering plug-in Found a bug, when the sky box texture is set, SUNFLOW engine rendering ray tracing will become completely black ![]() |
| Posted by enkonyito at Oct 5, 2022, 8:49:58 PM |
Re: Photo-video rendering plug-in @varigonda When you click on Stop, the Save button becomes available if rendering has stopped correctly and it is possible to save your image. If not, your rendering has terminated abnormally. @YGYL To use Path global illumination with a sky texture, sky lighting must be enabled. ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Dec 31, 2022, 8:54:43 PM |
Re: Photo-video rendering plug-in @Puybaret It would be better to reuse the DLLs available in Sweet Home 3D in your plug-in, but then you'll get the error you reported. As removing these DLLs from your plug-in will prevent it to work with older versions of Sweet Home 3D, I think it's better to keep them with your plug-in for the moment. Indeed, it is more practical to keep the YafarayRendering-1.4.5 plug-in dlls otherwise it would have been necessary to create a version derived from SweetHome3D-7.0. A question that has nothing to do. How to modify the luminosity of the sky (color or texture) as it is already the case for the ground with Java3D (3D view)? ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Apr 1, 2023, 12:43:54 AM |
Re: Photo-video rendering plug-in PhotoVideoRendering-2.5 plug-in
Current timezone is GMT Sep 14, 2026, 7:25:52 AM |
