Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Photo-video rendering plug-in |
| Print at Sep 14, 2026, 7:25:50 AM |
| Posted by udornbusch at Oct 13, 2020, 10:21:40 PM |
Re: Photo-video rendering plug-in Brilliant, thanks. I didn't try the slider so did not see this which is - once one knows - quite a nifty way to do this; but wasn't obvious to me. Thanks a lot! |
| Posted by Xlance at Nov 29, 2020, 4:38:45 PM |
Re: Photo-video rendering plug-in Hello A magnificent Plugin by all means ! >> I use "CameraBagPlugin" to create hundreds of Cameras Exceeding the 50 Limit, however I must select them one by one in Multi Photo Renderer" select dialogue. Any chance to add CTRL-A (SELECT ALL) function or SHIFT-ARROW selection ? Much appreciated Vic ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
| Posted by enkonyito at Nov 30, 2020, 4:02:41 AM |
Re: Photo-video rendering plug-in PhotoVideoRendering-2.1 plug-in
Enko ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Nov 30, 2020, 4:03:55 AM |
Re: Photo-video rendering plug-in Hello A magnificent Plugin by all means ! >> I use "CameraBagPlugin" to create hundreds of Cameras Exceeding the 50 Limit, however I must select them one by one in Multi Photo Renderer" select dialogue. Any chance to add CTRL-A (SELECT ALL) function or SHIFT-ARROW selection ? Much appreciated Vic Maybe in a future version after studying the feasibility. ---------------------------------------- EnkoNyito |
| Posted by Ceciliabr at Dec 2, 2020, 4:16:58 PM |
Re: Photo-video rendering plug-in Hi Enko, I wonder if you could give us a short explanation about how the different settings behave: Direct lighting Ambient occlusion Path tracing Photon mapping SPPM I like that you have now increased the sample setting from max 16 to max 100. The SPPM setting is very useful, as you can stop it when it has reached an acceptable quality. Thank you! Cecilia |
| Posted by enkonyito at Dec 2, 2020, 10:38:02 PM |
Re: Photo-video rendering plug-in Hi Cecilia, I wonder if you could give us a short explanation about how the different settings behave: Direct lighting Ambient occlusion Path tracing Photon mapping SPPM As the YafaRay web site is inaccessible, their team have made their docs available here. What I can say about the settings I've implemented: Direct lighting (direct light, hard shadow, equivalent to SunFlow diffusedBounces=0) Ambient occlusion (direct light, less dark shadow with brightness dependent on time of day) Path tracing (indirect light, editable number of bounces, caustics visible from 3 bounces) Photon mapping (indirect light, predefined number of bounces, predefined number of photons) SPPM (indirect light, predefined number of bounces, predefined number of photons, editable number of passes) I like that you have now increased the sample setting from max 16 to max 100. The number of samples per pixel for YafaRay ranges from 1 (min) to 1024 (max). Correspondence with SunFlow: antiAliasing 0 = 1 sample per pixel antiAliasing 1 = 4 samples per pixel antiAliasing 2 = 16 samples per pixel antiAliasing 3 = 64 samples per pixel antiAliasing 4 = 256 samples per pixel antiAliasing 5 = 1024 samples per pixel When the YafaRay documentation will be updated on their new web site, it may be possible to properly implement caustic photons. Enko ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Dec 8, 2020, 3:37:34 AM |
Re: Photo-video rendering plug-in Hello A magnificent Plugin by all means ! >> I use "CameraBagPlugin" to create hundreds of Cameras Exceeding the 50 Limit, however I must select them one by one in Multi Photo Renderer" select dialogue. Any chance to add CTRL-A (SELECT ALL) function or SHIFT-ARROW selection ? Much appreciated Vic Maybe in a future version after studying the feasibility. I was able to add the multiple selection option. When opening the photos panel, do you prefer? 1- current behavior of the plug-in: 1st point of view selected 2- behavior identical to SH3D: all points of view selected These will be highlighted. Selection/deselection using the space key will not be available. ---------------------------------------- EnkoNyito |
| Posted by Baker0052 at Dec 27, 2020, 5:52:44 PM |
Re: Photo-video rendering plug-in Why is the rendering so much slower when i use the Photo-Video Plugin insted the yafaray plugin? |
| Posted by enkonyito at Dec 29, 2020, 5:32:08 PM |
Re: Photo-video rendering plug-in Why is the rendering so much slower when i use the Photo-Video Plugin insted the yafaray plugin? The YafaRayRendering plug-in uses a standard configuration just like the SunFlow rendering engine in the 'Create photo' panel. The PhotoVideoRendering plug-in uses an advanced configuration to maximize the properties of rendering engines (SunFlow, YafaRay). ---------------------------------------- EnkoNyito |
| Posted by Magokelvin at Jan 3, 2021, 11:03:26 AM |
Re: Photo-video rendering plug-in dear team... I am not posting so much in this forum... I am really an amateour of SH3D, for my porpuses I reached a good level of satisfaction in rendering. I was excited to read all about thsse rendering new features..but I have a question... when rendering with the menu optio create photo with yafaray I obtain a bright result (don't know how to post a photo here) when using the new 2.1 plug in...all of a sudden it becomes all dark? where do I make mistake? |
Current timezone is GMT Sep 14, 2026, 7:25:50 AM |
