Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Photo-video rendering plug-in |
| Print at Sep 14, 2026, 6:47:07 AM |
| Posted by bdfd at Jun 30, 2020, 9:41:30 AM |
Re: Photo-video rendering plug-inHi, Try this : Launch a rendering with version 1.9 by night (01:00 AM) with a night texture and the yarafay method... SH3D will crash quicky !!! Good search. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by enkonyito at Jul 27, 2020, 1:38:39 AM |
Re: Photo-video rendering plug-in Hi, Try this : Launch a rendering with version 1.9 by night (01:00 AM) with a night texture and the yarafay method... SH3D will crash quicky !!! Good search. . As you can see here, I have no rendering issues with the textures and sky lighting enabled at night. From your other post, the problem seems to be with an object in your project that YafaRay is having a hard time rendering. ---------------------------------------- EnkoNyito |
| Posted by bdfd at Jul 27, 2020, 8:56:48 AM |
Re: Photo-video rendering plug-in ... the problem seems to be with an object in your project that YafaRay is having a hard time rendering. Yes, I arrived at the same conclusion but which one ?Strange, it's OK in day light and no in night time ??? Never see before this in 10 years of SH3D... All other projects are OK. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by enkonyito at Aug 2, 2020, 2:56:55 PM |
Re: Photo-video rendering plug-in PhotoVideoRendering-2.0a plug-in - compatibility with version 1.3.2 of YafaRay plug-in EnkoNyito ---------------------------------------- EnkoNyito |
| Posted by GhyslainB at Aug 3, 2020, 1:01:30 PM |
Re: Photo-video rendering plug-in Thanks enkonyito! Version 2.0a works like a charm! ![]() |
| Posted by Ceciliabr at Aug 3, 2020, 8:21:28 PM |
Re: Photo-video rendering plug-in Perfect! Thank You! Cecilia |
| Posted by Atefth at Aug 17, 2020, 9:29:43 PM |
Re: Photo-video rendering plug-in Hello All, Is there any way to do rendering on GPU ? Thank you. |
| Posted by enkonyito at Aug 18, 2020, 12:57:19 AM |
Re: Photo-video rendering plug-in Hello All, Is there any way to do rendering on GPU ? Thank you. Hi Atefth, The rendering engines currently available (SunFlow and YafaRay) do not allow GPU rendering. Enko ---------------------------------------- EnkoNyito |
| Posted by udornbusch at Oct 10, 2020, 11:21:28 PM |
Re: Photo-video rendering plug-inThis sounds silly, but after an hour of trying I cannot see any advanced photo or video rendering options. I have downloaded and installed "PhotoVideoRendering2.0a.zip" and also tried "YafaryRendering 1.3.2" but in both cases the window that opens for photos shows just the space for the photo and the 'width' and 'quality' lines and the buttons to 'create' and 'close'. There is no options to enter the time etc. For the photovideorendering plugin there are only 3 options in the plugin drop-down (Simple photo rendering (v2.0a),grayed out multiple.. and Video rendering (v2.0a)) I am using version 6.4.2 I am a bit at a loss as to what to do. Thanks! |
| Posted by enkonyito at Oct 11, 2020, 11:41:03 PM |
Re: Photo-video rendering plug-in @udornbusch This sounds silly, but after an hour of trying I cannot see any advanced photo or video rendering options. I have downloaded and installed "PhotoVideoRendering2.0a.zip" and also tried "YafaryRendering 1.3.2" but in both cases the window that opens for photos shows just the space for the photo and the 'width' and 'quality' lines and the buttons to 'create' and 'close'. There is no options to enter the time etc. For the photovideorendering plugin there are only 3 options in the plugin drop-down (Simple photo rendering (v2.0a),grayed out multiple.. and Video rendering (v2.0a)) I am using version 6.4.2 I am a bit at a loss as to what to do. Thanks! SunFlow or YafaRay rendering engines can only be used at quality level 3 and 4 (best) where the date, time and lens are visible. The PhotoVideoRendering plug-in also adds to the simple photo panel: the selection of the rendering engine, its advanced settings and the activation of sky lighting. This is where you have to make the settings that also take effect in the multiple photo panel (stored points of view) or the video panel. Enko ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 14, 2026, 6:47:07 AM |
