Hi, when I try to boot a file it is necessary a lot of minutes to complete the boot. There is an icon like a clock over every object. At boot terminated the render 3D do not work properly, it go at step (very slow). I update at 5.6 version and also Java is updated. Since some week ago all was OK. My notebook is HP Pavilion I5 with 8 Gb ram.
Thanks for help
Marco
File boot and 3D problem
This topic has been viewed 3961 times and has 9 replies
- bdfd
Re: File boot and 3D problem
OS ?
Size of your file ?
zipped or not ?
Try to delete heavy objects...
OS ?
Size of your file ?
zipped or not ?
Windows 10 home edition.
File size 100 MB
"zipped or not" ? what means
Where I can see the size of objects?
Thanks
File size 100 MB
Thanks
- bdfd
OK.Hi,
2 ways to save a file :File size 100 MB
"save as" and "save and compress"
What did you do ?
Right click on the list in lower left frame and choose "display column" and "size model"...Where I can see the size of objects?
I save only "save as".
What is (apart save MB) the difference if you open an use a compressed o not compressed file?
And, what about my problem ? Do you know a possible solution
Thanks
Thanks
- bdfd
I think that W10 home, 8 Go and 100 MB are not enough for sh3d and java... [:((]
Marbel, you should try to increase the max memory used by the program, unless you use the 32 bit version of Sweet Home 3D (see in the About dialog of Sweet Home 3D).
I am using: Sweet Home 3D ®
Versione 5.6 Java Web Start
Versione Java 1.8.0_151 / 32 bit / 0,6 GB max
Versione Java 3D 1.6.0.
Is a 64 bit version for windows??
If yes, how much can I increase the max memory for the program (I have 6 Gb ram). Thanks
If your system is 64 bit, try the installer version which will install Sweet Home 3D 64 bit.
OK, thanks
