High priority File boot and 3D problem
This topic has been viewed 3595 times and has 9 replies
Marbel
Country: Italy
Post by Marbel »
Hi, when I try to boot a file it is necessary a lot of minutes to complete the boot. There is an icon like a clock over every object. At boot terminated the render 3D do not work properly, it go at step (very slow). I update at 5.6 version and also Java is updated. Since some week ago all was OK. My notebook is HP Pavilion I5 with 8 Gb ram.
Thanks for help
Marco
Re: File boot and 3D problem
Post by bdfd »
OS ?
Size of your file ?
zipped or not ?
Try to delete heavy objects...
Marbel
Country: Italy
Post by Marbel »
Windows 10 home edition.
File size 100 MB
"zipped or not" ? what means
Where I can see the size of objects?
Post by bdfd »
OK.
File size 100 MB
2 ways to save a file :
"save as" and "save and compress"
What did you do ?
Right click on the list in lower left frame and choose "display column" and "size model"...
Marbel
Country: Italy
Post by Marbel »
I save only "save as".
What is (apart save MB) the difference if you open an use a compressed o not compressed file?
And, what about my problem ? Do you know a possible solution
Post by bdfd »
I think that W10 home, 8 Go and 100 MB are not enough for sh3d and java... [:((]
Marbel, you should try to increase the max memory used by the program, unless you use the 32 bit version of Sweet Home 3D (see in the About dialog of Sweet Home 3D).
Marbel
Country: Italy
Post by Marbel »
I am using: Sweet Home 3D ®
Versione 5.6 Java Web Start
Versione Java 1.8.0_151 / 32 bit / 0,6 GB max
Versione Java 3D 1.6.0.
Is a 64 bit version for windows??
If yes, how much can I increase the max memory for the program (I have 6 Gb ram). Thanks
If your system is 64 bit, try the installer version which will install Sweet Home 3D 64 bit.
Marbel
Country: Italy
Post by Marbel »
OK, thanks
