vertical rounded wall
This topic has been viewed 4587 times and has 2 replies
paddifly
Country: Germany
Post by paddifly »
Hello,is it possible to create a wall, which is left side rounded vertical by a specified radius?? thanks for any solution [:)] .
Ralf
Re: vertical rounded wall
1st method
- insert an invisible, insertable cylinder
- doesn't work because the cylinder makes a square cut in the wall, not a rounded one
2nd method
- draw a wall that has the desired curvature
- export and import it, rotating it 90 degrees
- could work for a straight wall, but will cause problems in corners
3rd method
- use another program
Sorry
Post by bdfd »
@hans,
4th method
- Maybe with a hollow cylinder and adjusting walls, floor and ceiling ???
=> It will be not easy ! [:D]
