3d models not supported
This topic has been viewed 8321 times and has 8 replies
hobbyrv
Country: Berkel en Rodenrijs
Post by hobbyrv »
I want to import furniture and textures. But for a lot of objects I then get to see that the chosen model is not supported. I looked in the FAQ, installed FBXconverter, but it is still abacadabra for me and I don't know if that's the right thing to do. So I hope you'll forgive me that I ask you what to do to be able to import more objects from the sites on the page '3D Models Import', when they appear to be not supported. Can you provide me with a step-by-step guide.
Re: 3d models not supported
Start your reading here ....
hobbyrv
Post by hobbyrv »
Thank you,but I already knew that. But some I manage to import, others not. My question is about the models that are not supported, when I import them. Or in dutch: een aantal kan ik gewoon importeren, maar een aantal ook niet. En hoe kan ik die laatste toch mogelijk maken?
Your description is rather vague. "Some"?? Which ones?
Sweet Home 3D supports 3D model files at OBJ, DAE, 3DS format, ZIP files containing a file of this type, and KMZ files.
These are the files you can import directly.
Files in other formats have to be converted first to one of the supported formats. There are websites that provide this conversion service, or you could use a program like Blender .
Could you give a link to a model you didn't succeed to import?
hobbyrv
Post by hobbyrv »
https://3dwarehouse.sketchup.com/model. ... e24ac51624
https://3dwarehouse.sketchup.com/model. ... d579d8a24e
and others. When I see it when working on my design, I will also report them, if still neccessary.
Are you sure you downloaded the Collada file (.dae) when you download from the 3D warehouse - as described in the 3D Models import page and the FAQ ?
Tried both models, and they both imported with no problems at all. (Btw: Flexform Piuma Cabinet has textures applied only to one side of its surfaces, so it may not render as nicely as it should - but that is more a design shortcoming than a SH3D issue).
swave
Post by swave »
Just to support the OP, I also had models downloaded in the correct format but upon import was told that this format is not supported. I'm assuming that even the same format type can have different generations and therefore not always work. But I don't have any links of such models as I just deleted them and tried some other.
Be sure to follow this suggestion when you download a model from Trimble 3D warehouse.
swave, I can't test all the models submitted in Trimble 3D warehouse. So if you find one that doesn't seem to be supported by Sweet Home 3D, please take the time to post here a link to that model, otherwise there are no chance that I fix the issue.
