confused High priority Adding lights to my house
This topic has been viewed 21712 times and has 7 replies
choppyleo
Country: Yaounde, Cameroon
Post by choppyleo »
Please I have adding lights to my house but don't know how to put it on cause by default it's off I guess.
Maybe that is why I can't see the effects of lights in my house every where seems to have the same intensity of natural light. Not from the bulbs I added.
Can someone please explain to me how to put lights ON or tell me what am I not doing right?
Re: Adding lights to my house
There are two types o f lamps in SH3D:
- lamps with light
- lamps without light.
When a lamp has light, do Modify furniture and at the bottom left you see a Light power (%).
There is a way to add light to a lamp, described by user OKH. You can read about it in this short manual (PDF).
In addition to what hansmex correctly writes, you may want to consider:
- The easiest way of adding lights, is to use the included light-sources in the library and place them where the lamp is.
- Lights have a default power of 50%.
- Lights will only show in photo-rendering (highest qualities).
- Lights are not very visible if they compete with sunlight, try a time later in the evening.
- The "auto ceiling lights" checkbox may interfere with the effect of accurately placed light-sources.
- Pay attention to the colour of the light-source you choose.
choppyleo
Post by choppyleo »
Thanks hansmex I have tried but I get maybe I don't understand how to do it. Can someone direct me or have a toturial on the light issue
Depends what you want to do, the easiest is to combine your models with the light-sources included in SH3D. That is easy, and you can group lamp and light-source.
Adding light-sources to your own models in a library requires some more work, but you will find several threads in the forum discussing this, like this recent one.
choppyleo
Post by choppyleo »
Thanks guys I have tried and seems to still have problems to render the bulbs glowing. Can someone mail to me a simple project with the light demonstration.Please its very important and kind of urgent. Thanks in advance
The light sources included with SH3D are invisible (just represented with bulbs in furniture list), so you need to add lamp/bulb.
Sent you a file - maybe that makes it clearer.
Hi choppyleo, the blog post on how to design a swimming pool, with an example .sh3d file, is a good demonstration on how to use light-sources too.
How to design a swimming pool
Image[/quote]
